I doubt that an occasional use of alum would ever generate concerning sulfate levels (~300 mg/l from here
3 – Sulphate attack | ) like sodium bisulfate use would, but extremely frequent dosing certainly could. You could also acheive the same results with polyaluminum chloride floc without the sulfates.
Of course the occasional or one-off use wouldn't be harmful. However, not all pools experience constant water exchange and sulfates do not go away without fresh water to remove them, so my thinking was more along the lines of pools that could suffer sulfate build up. Polyaluminum chlorine is certainly a better choice but it is not widely available as a pool chemical. Perhaps in the WWTP world it is very common, but for pool chemicals, not so much. I think HTH might be the only supplier of PAC flocculant.
I actually considered alum but was concerned about my new swg since the mfg specifically advises against use of dry acid.
What I am curious about is the following, so please share if you know or point me to a resource:
1. What volume of ppm can alum remove per quart per 10,000 gallons if known?
2. If one uses alum as a true floc, shutting down the filtration and vacuuming to waste, do sulphates remain as a byproduct, or would they get caught in floc?
3. In your wastewater setting with your background in municipal water treatment, how are municipalities who use metal sequestrants managing accumulation in equipment? Or is it that unlike boilers, the polyphosphates are injected at a particular level then move on?
Other info I'd love to know is has your municipality studied the rate of breakdown of polyphosphates to orthophosphates?
Thanks in advance to your contributions
P.s. I also had been given to understand that alum is most effective at a ph of 8. However, those of us on well dread allowing ph to rise due to metal precipitation and staining. At the same time, I believe I was told alum floc can also reduce iron.
Any thoughts on this combo of needs
Swampwoman,
Since we're having a splash-battle
in
The Deep End, let me see if I can at least answer questions #1 & #2 -
As for how much can be removed, let's look at the possible chemical reactions involved in removing phosphates. For potassium alum, a reaction would like this -
Al(SO
4)
2- + PO
43- ----> AlPO
4(s) + 2•(SO
4)
2-
(I left out the spectator ions, like potassium (K) because they are of no consequence to the overall reaction)
For lanthanum chloride, it would look like -
LaCl
3 + PO
43- -----> LaPO
4(s) + 3•Cl
So, in both cases, 1 mol of either lanthanum chloride OR potassium alum will neutralize 1 mol of orthophosphate. Now, if you take, for example, pool water with 1ppm (1000ppb) orthophosphate (PO
43-) in it, then the concentration of orthophosphate is -
1ppm = 1 mg/L = 10.53 µM/L [PO
43-]
The molecular weights of our phosphate removers are -
MW
Alum = 258.205 gm/mol
MW
LaCl3 = 245.26 gm/mol
SO now you can find out the ppm's of remover needed to eliminate the 1ppm orthophosphate concentration -
Alum : 10.53 µM/L x 258.205 gm/mol = 2.7189 mg/L = 2.7189ppm Alum
LaCl3 : 10.53 µM/L x 245.26 gm/mol = 2.5826 mg/L = 2.5826ppm LaCl3
In a 10,000 gal (37,854 L) volume of water, you get the following amount by weight -
Alum : 102.9 gm
LaCl3 : 97.76 gm
I used the Sigma-Aldrich website for pricing and looked at technical grades of both chemicals. Lanthanum chloride costs ~ $1 per gram while Potassium Alum costs ~ $0.41 per gram. So, based on the small differences in weight needed and the price, alum would appear to be a better choice. The only problems I see with it are (1) potassium alum leaves sulfates behind in the water with use, not a lot, but some and (2) reaction efficiency. Lanthanum chloride specifically reacts with the carbonates and phosphates in pool water to produce the removal reaction and does not react with anything else in any significant way. Alum, on the other hand, is a flocculant that will react with lots of particulates in the water to help bind them up. So there's no way to predict how efficient the reaction with free orthophosphates will be. I suspect in practice one would have to use more alum than predicted by the chemistry alone.
As for your Question #2 about sulfates, the answer is no. Sulfates are highly soluble in water and will simply go into solution and not get floc'd out in any way. The only reaction I know of that removes sulfates is the standard quantitative chemistry method for measuring sulfate concentration. That is, you mix a solution of barium chloride (very soluble in water) with a water sample that contains sulfates and the barium cation will react with the sulfates and form an insoluble precipitate of barium sulfate which you can filter and dry out to weigh. Barium sulfate is used in radiology as a contrast medium for CT scans of the intestine. Barium sulfate is completely insoluble in water and is not absorbed by the human gut but, because the barium atom is extremely heavy, it give good contrast on a CT scan. Anyone that has ever had a "barium enema" will attest to it's unpleasantness
Matt
