I'm still curious about the warnings of high Po4 levels absent of CH levels. Why do they say it's still somewhat theorhetical that phosphates are a problem for SWGs?
I've been pondering this too, Patrick, and have one of my half-baked theories bubbling away. I have a feeling that at mfgs what the "science guys" think in product dev and what the customer service people relate may be two different things.
Like us, I think the manufacturers are "trying to keep it simple" in a case where there really are too many variables to account for. Most folks gripe about (and often don't even use) simple test strips, let alone scary ole drop kits or Egads, a phosphate test that only goes up to 5,000. Explaining to a consumer what I'm about to attempt might divert a sale or two or three
This is the picture that's sort of emerging for me:
1. Temperature variance, ph, and calcium levels all contribute to whether high phosphate levels will scale a cell, making it much more difficult to formulate an accurate level/condition combination that's adequately predictive. You saw chemgeek's formula. I'm inqusitive by nature that that math still gets away from me
2. Po4 scaling is supposed to be difficult to detect vs ch scaling alone - homeowner not likely to detect visually so its easier to theorize on a "functioning/not functioning" scale.
3. Cell longevity is related to rate of use...a T15 cell is rated equivalent of 500 lb of chlorine. Run time affects output. Good cell life makes for happy customers.
4. In my experience, extremely high phosphate levels do not equal algae if the FC : cya ratio is maintained, but to get the predicted lifespan out of a cell, nobody's recommending running at this ratio, plus industry guidelines don't acknowledge this ratio (though I've seen that starting to change.)
So 5. Someone with constantly high ph and ch and PO4 from anti stain and scale products is perhaps more likely to scale...but no swg mfg is going to tell someone not to use sequestrants...on the contrary, salt plus electrolysis/galvanization makes staining more likely
I'd asked the Seaklear rep about this, and his co. sells EDTA for this purpose and he would NOT recommend that I not sequester for these reasons
6. At the same time, some people try to reduce their pump times to save on energy. Telling a consumer to run their pump for 24 hours is again going to make for an unhappy consumer.
7. In reality, here at TFP, we assume a lower FC:cya ratio for swg because we're also assuming enough run time to keep the lower level constant instead of dropping by a few ppm the way manual dosing does. But that doesn't mean some short run and undersized cell users AREN'T dropping below recc levels for much of the day, depending on sun, when they run pump, etc. We tell them to dial it in, as we should. But swg folks not on TFP might find "dialing it in" a hassle, right?
8. Low FC levels plus high phosphates lead to algae conditions, which also make consumers unhappy with swg purchase decisions once a cell can't get ahead of nascent conditions...just like high cya puck users. A swg mfgs direct competition would be a convenience-focused puck user...
9. For these reasons combined, it would be easier to "train" people to simply treat to keep PO4 LOW enough that the lowest possible levels of FC still keeps the water clear -- from the mfgs perspective.
It keeps SWG looking simple, and dare I say it, Trouble Free. (Which it certainly can be in the right hands.)
Now WE know that true trouble free status comes from a deeper knowledge of variables/conditions, and the ability to accurately test the water as needed, and reduce unintended consequences by generally only adding known entities to the water.
But hey, commercially, that's a hard sell if your key feature is convenience and the product counter-positioned to you in the market is equally "convenient" -- and your competing product -- pucks -- are getting on the phosphate bandwagon to excuse an ineffective FC:CYA ratio
SO with the myriad of pool water treatment products out there, rather than getting highly specified with consumers, rather than trying to sleuth out what all agents of action are in a pool the way WE often do (which I freely admit is very difficult and time consuming)...in terms of warranty guidelines instead of setting highly arbitrary PO4 levels, which would be conditional on not only ph, temp, ch, po4 but also in terms of production, cell size and run time practices... companies like Hayward are saying "Bring your cell to a testing center. If we can produce chlorine with it, talk to an expert to sort out your water conditions."
When I reason it out, I actually think I agree with their position
And on the customer service front if a happy customer is a customer without algae, then telling them to maintain an arbitrary but unspecified "low" PO4 level may in fact help customers remain satisfied with their purchase decision because its helping their water stay clear despite lower-than-effective FC
Do you have a headache yet?
SO...the reason I've been very slow to change to SWG was because I am a different purchaser for them than perhaps the typical consumer. I accept the trade off of convenience in terms of hauling liquid chlorine to fiddling with the mechanics, thinking about my treatment protocol, actively controlling ph if necessary, recognizing that with metals, I'm best served first reducing metals in my source water, etc. to minimize sequestrant, etc. (which is why I doubled down on softener capacity before entertaining a switch...I now have both a soft water spigot plus a well water zpm plumbed for a drip irrigation system I'm putting in the terrace...no small expense in terms of set up, I might add, but one meant to last my years)
I'm also willing to spend a few hundred to attempt to clear or reduce my PO4 levels to increase the odds of swg being an effective treatment method for me, because its cheaper than trucking in new water or replacing a well
For me, with my habit of buying refilled chlorine because I hate environmentally using so many plastic bottles, in terms of cost, even two years of cell life is a wash financially, so I'll run it as high and hard as I need to to keep my sparkly water.
With all of that, if I find swg isn't a fit for me, I'm not too worried because I know what to do
So, the techs come out April 18 to open for me, and I've ordered 2 gallons of Seaklear commercial.
If Matt clouded after 8 oz and 30 min., my experiment may be hilarious in scope
I promise to take pictures!
If all goes well, the cell itself will be installed April 25th, with electrician coming sometime thereafter. On the 25th we're doing a one-time sand change because its too hard to move filter outside of the pool house for a deep clean and it hasn't been cleaned since the swamp recovery four years ago. I also expect it may be full of phos-goo by then
