Thanks again Matt. I'll let you all know what I do and what the results are. I won't end up being as quantitative as you because I haven't been keeping actual data, and my pool is crystal-clear now, but I'll try to post something useful.
I use the K-1106 phosphate test kit from Taylor. It's a color comparison test that goes up to 1000ppb but, admittedly has a very limited color resolution chart. The test kit runs about $20 or so.
I believe swampwoman uses the Hanna Instruments electronic colorimeter tester as found here -
Hanna Instruments HI713 Phosphate Low Range Checker® HC: Science Lab Calorimeters: Amazon.com: Industrial Scientific
It is better in terms of measuring but I would definitely check calibration and accuracy. I believe Hanna also sells standards as well to ensure the device is operating properly. You do pay a premium for it though - $50 for the tester.
In other news, since I have fresh water coming in, I read the treatment plant water test ... 1750 ppb po4...much lower than I am but if one believes the "500" ppb guidelines for swg cells, then anyone on treated water in West Michigan is already 3 times the limit on a freshwater fill![]()
As Matt pointed out, you need rather high calcium AND phosphate levels to get significant precipitation, though in an SWCG cell the pH is higher so the phosphate level is higher as a result. This post gives the best formula for predicting calcium phosphate scaling. If I assume 25,000 ppb phosphate and solve for calcium hardness I get the following and I'll use 30ºC (86ºF) tempertaure and 7.5 and 8.5 pH:
pHc = (11.755 - log(ppm CaH) - log(ppm PO4) - 2log(ºC)) / 0.65
CaH = 10^[11.755 - log(ppm PO4) - 2log(ºC) - (0.65 * pH)]
CaH = 10^[11.755 - log(25) - 2log(30) - (0.65 * 7.5)] = 337 ppm
CaH = 10^[11.755 - log(25) - 2log(30) - (0.65 * 8.5)] = 75 ppm
I know this is a long-dead thread but today I've had an experience that corroborates Smallpooldad's experience and wanted to post it for posterity.
I changed my heavy-phosphate-level water mid-August during a liner change.
I had city water trucked in.
I continued using Jacks Purple for SWG, because I was still getting lw level iron staining, that as it turns out, may have been coming from an old, coroding ladder subsequent to swg switch. I don't ave the sequestrant test kit, so have used the recommended maintenance dose on the bottle.
10 weeks later, I read the po4 level with my hi limit Hanna tester: 11,400 ppb aka 11.4 ppm. In other words, about 1,000 ppb a week since clean start after start up dose.
Right now, I am keeping water super hot for imminent installation of a dome next week, and with leaf traffic, can't do a phosphate removal floc at the moment. But running a heater hot will likely mean that I will soon have to do so to avoid the kind of phosphate scaling I was getting prior to the water change.
At this point, based on my experience to date, I personally believe the rate of HEDP breakdown is substantially faster than any of the mfg techs would have one believe.
Smallpooldad and I were using the same product and experiencing the same rate of po4 accumulation in terms of ppb per week. He is in Hawaii and I am in Michigan.
Since I am currently not seeing scale shedding from returns, I will begin weekly po4 reduction treatments to get through the winter without doubling or tripling my po4, since in my case the scaling seems to occur in the 25,000+ range. I will then do an alum floc come spring.
I am awaiting your end-of-year results, Joyful....
