I had my pool resurfaced in March of 2019 with QuartzScapes plaster. I have to put muratic acid in every other day. The PH will be a perfect 7.2 when I add the acid but in a couple of days it is above 8(almost purple in test tube). My pool surface has also developed brown stains all over the bottom. All other measurements are in good range. I use only liquid chlorine. The CYA is low, maybe in the 25ppm range. Alkalinity stays around 90, hardness is 220, chlorine is between 3 and 4 ppm. My pool was originally built in 1997 and has been resurfaced only the one time in 2019. The plaster looks way worse now than it did before resurfacing. Any idea what is going on?
