Replastering was done on this pool 2.5 months ago. Every week I have been noticing that the pool service adds acid to bring the PH level to 7.2. PH level then starts increasing and at the end of the week, it is at 7.8. Is that normal or should the PH be expected to stay within a smaller range?
Current results (middle of a pool service week) from TF-100:
PH: 7.5
TA: 50 ppm
CH: 500 ppm
CYA: 60
FC: 7
CC: 0
Water temperature varies from 78 to 82 (solar heating).
Phosphates (Leslie's measured it) - high and out of range, but don't remember the number
Every week, I add about 50 cf of fresh water (375 gallons) an hour or so before the pool service adds acid to compensate for evaporation (3/16" - 1/4" per day. That is about 2.75% of the pool's total volume. Before adding fresh water the PH is around 7.7 or 7.8 already. Pool service then adds enough acid, and I measure the PH the next morning, and it is usually at 7.2.
Fresh water chemical levels is at
TA: 90
PH: 8.4+
CH: 30
PH: 7.5
TA: 50 ppm
CH: 500 ppm
CYA: 60
FC: 7
CC: 0
TA: 90
PH: 8.4+
CH: 30
