Guys
For PH measurement I am using palintest pool tester.i attach the picture of the tester below
I live in iran and I don't have access to taylor test kits
Readimg PH - Further Reading from TFP i came to this below:
" The Taylor R-0004 pH Indicator solution has a proprietary combination of chlorine neutralizers already in it that try and keep the pH the same when chlorine gets neutralized, but there's only enough to neutralize roughly 10 ppm FC or so of chlorine. "
Does anybody know whether palintest phenol red tablets for measuring PH contain ANY chlorine neutralizers in them in order to have an accurate PH measurement especially when we are dealing with free chlorine level between 4-6 ppm with 30 ppm CYA in the water?
Does this FC amount effect the accuracy of the PH test?
I treid to contact palintest but it is hard to receive an answer from them
