Any recommendations would be much appreciated regarding PH/TA levels. Some quick background, the pool was completed and filled in July 2021, it's a gunite/plaster/SWG setup.
I've had to add MA just about every 2-4 weeks as my PH likes to creep up to 8.0-8.2 since the pool was opened. I've never seen it higher than 8.2, but then again I've never let it go above. My TA this whole time is ranging between 80-95. When I add MA to drop the PH from 8 to 7 (to lower my TA per pool math) my TA will respond and come down to 80. However, once I aerate to bring the PH back up to around 7.6 the TA rises back to around 90 as well. It never gets much higher but any advice how I can better stabilize these values? Or am I simply chasing these too much? i.e. The TA around 90 is fine and just continue to maintain the PH in the mid 7's with MA as needed and stop worrying about TA?
Thanks in advance!
Thanks in advance!
