FC=3.5
CC=0
pH=7.5
TA=130
CH=225
CYA=0
Salt=3200
Temp=86
So numbers were worse a few days ago, with pH at 8.4. I concentrated on pH 1st and got it down to 7.5, but that is as far down as it will go. Pool Math says to get pH to 7.0-7.2 to lower my TA to the goal of 70. What should I do?
Today, I've started tackling the other levels starting with CYA. I just added 2lbs (it's all I had on hand) of CYA. I'll keep adding 2 lbs at a time to get to the target of 75.
What else should I be doing?
CC=0
pH=7.5
TA=130
CH=225
CYA=0
Salt=3200
Temp=86
