Knock on wood, the only problem this season. The water has been crystal clear all year. Here are readings from yesterday (we use PoolMath to track all activity):
FC 6.5 pH 8.0 TA 85 CH 325 CYA 60 CSI 0.38 Temp 84
Acid was put in 6 days ago, dropped pH to 7.6 but it bounced back up; this has happened repeatedly. The only other comment I could make is we're getting what I think is mildew on the floating thermometer where it gets wet then dries, and in the skimmer above the waterline. Both clean off rather easily with Mr. Clean Magic Eraser.
Suggestions are appreciated.
