Hi, I’m going to be closing my new gunite pool in about a month and I’m curious how the constant ph rise is addressed during a winter close. I’m waiting to close the pool until it is about 60 degrees consistently as you guys suggest however that just helps avoid opening to algae. Do I just leave it covered all winter and ignore the constant ph rise? I know high ph leads to scaling, does the cold water also lower the risk? With no pump running there is no way to circulate acid even if I wanted to test and add it during the winter.
