This is my 3rd summer with TFP. My challenge this year, is that my pH seems to be creeping up. Over the course of less than a week, I'll go from 7.2 to 8.2+. I've been adding MA pretty much weekly.
My last test results:
FC 4.0
CC 0
PH 8.2
TA 70
CH 350
CYA 40
I didn't have problem with this so much last year. I added MA maybe 5 times throughout the season. I do have a spillover spa, that we run about an hour a day, to circulate it into the main pool (I test/treat as one body). I ran it the same last year, without the constant creep issue. We don't regularly fill the pool - we let nature do that, and if we have to add water, it's just a couple times in the season (so far) from straight well water.
Suggestions?
My CH is on the high side because I'm trying to see if I can reduce the corrosion going on with my float hookoffs, and flaking surface on the steps. I've kept the CH on the low side in the past, but I'm hoping that raising it will decrease corrosion and flaking. think it will work?
FC 4.0
CC 0
PH 8.2
TA 70
CH 350
CYA 40
Suggestions?
