What does it mean when the pool ph tests at a 7.2 and then within 2 seconds starts to change before your eyes, rising to an 8.0? The Alk. Is low at a 60 and the chlorine is reading a 2.5.
Welcome! Hummm... odd. Can you clarify:
- Which test kit you are using and how exactly are you performing the pH test?
- Enter the test kit along with all of your pool and equipment details into your signature as well.
- How do you chlorinate?
- Any new or unusual chemicals been added recently?
The test kit is a Taylor liquid reagent kit. I determined that the ph is extremely low. The color was going from a 7.0 to above an 8.0 in under 10 seconds. The pool is an indoor 17,000 gallon pool. We use sodium Hypochlorite to chlorinate and Co2 to lower the ph. We do Muriatic acid drops to deal with high Alk.
