My son is trying to get his above ground pool (about 19,000 gallon) cleared up after the winter. He just had it in shock mode for a few days and the water is looking much better compared to the "swamp" he had last week. The water is still somewhat cloudy but last night he passed the OCLT test with only 1ppm FC loss. Last week his ph reading was off the chart high but today the reading started at about 7.3 and fairly quickly changes higher to about 7.6. I wish I had testing his FC level but didn't because it was pouring rain. I suspect it may be on the high side since he was in shock mode until yesterday. Last week when we started his test levels were.....
FC = 0.0
PH = 8.4
TA = 60
CYA = 25
CH = ? didn't test
So what I'm wondering is what might cause the ph reading to change from 7.3 to 7.6 within a minute or two? Which reading should we believe ? How to best clear up the cloudy water ? It's not real bad but you can't see the pool bottom and as I said it's an above ground pool.
Thanks, Dave.
FC = 0.0
PH = 8.4
TA = 60
CYA = 25
CH = ? didn't test
Thanks, Dave.
