- Mar 5, 2020
- 3,084
- Plaster
- Astral Viron V35
As revitup said. I also do other tests while waiting for the meter to stabilise. The smiley usually appears pretty quickly, but I leave it a bit longer usually.
If you just want a quick "yes, my pH is the 7s", then about 30sec is probably enough. If you want to be a bit more nerdy about it (aren't we all a bit nerdy round here?), Then you can wait a bit longer.
The important bit (to really make use of the two digits of the pH60 and not just get fooled that you have a very precise measurement) is to make sure that the temperature that the meter shows is sufficiently close to the actual water temperature, otherwise the meter will use the wrong temperature for the automatic temperature compensation.
In summer that thermalization is pretty quick. In winter, when putting a room temperature meter into near freezing water, it can take a bit longer. I usually wait until the meter's temperature is within 2°C of the water temperature, that gives me very reproducible readings. When the water is very cold, the water sample should be sufficiently large, so that the meter actually cools down to the water temperature and not the other way round.
