- Apr 6, 2020
- 7
- Plaster
- Hayward Aqua Rite (T-15)
Hi,
I've got an Aqualogic SWG system - and have been happily running using the TFP recommendations for pool chemistry levels for a SWG pool for the last 5 years. I've been through 3 generic salt cells in that period - and had one replaced under warranty - and definitely seen the behaviors where a declining salt reading on the cell was i) a failing salt cell or ii) poor flow rate, on different occasions. I've even done the repair of the Aqualogic board where one of the solders had come undone - and got that working again.
What has been going on for the last couple months is a bit different - salt cell readings are good, but what I've noticed is my PH is no longer rising in the pool. It used to be like clockwork - every 2 weeks, half a gallon of muriatic acid in the pool to drop the PH from 7.8 to 7.2, rinse and repeat. Now it seems stuck at 7.2 My free chlorine level is also low - running at 1.5 to 2 - and I've struggled to raise it using the super chlorinate function. I've resorted to tipping in a gallon bleach occasionally - but not enough to make me think the salt cell isn't producing any chlorine at all (l live in Texas and it is summer). In the days before this I was running free chlorine in the 8 to 10 range. CYA is between 60-80.
The particular salt cell I'm using had been cleaned using a muriatic acid solution as per the instructions, so isn't new. Probably about a year old. Its a Calimar.
Is it the obvious thing - i.e. another duff salt cell not producing chlorine - or something else? If I'm buying a new T-15 salt cell any recommendations - I've used optimum pool technologies and Calimar so far.
Thanks in advance to y'all. TFP is awesome.
