Hi, I ordered a pH meter from TFTests. I was reading the directions and had a couple questions. Can anyone help?
The directions say to calibrate in buffer solution and to recalibrate periodically:
-What is "deionized water" referred to in the buffer solution directions? Where would I get it?
- Do I use the entire envelope for the test? If so, where do I get what I would need to recalibrate in the future
-How often should I calibrate?
For the pH directions t says to clean electrode with distilled water and suck it with filter paper.
-is distilled water the same thing as deionized water? If not, where would I get that?
-Does this needs to be done every single time it is used?
-would filter paper be something like a coffee filter?
It looks like the model number is PH-009(l)A The meter has the initials ATC on it.
Thanks!
Thanks!
