Hello,
I am new to this site and trying the methods outlined here. I have a Taylor K-2006C test kit with the following results.
FC = 2.6
CC = 2.4
CYA = 50
TA = 200
CH = 180
PH = Below 7.0
Based on my CC I was going to SLAM the pool. My concern is that my PH is too low to start the SLAM. When I tested PH and did the base demand test (reagent R-0006) it took 20 drops to get my PH up to 7.2. The chart within the Taylor guidebook only goes up to 10 drops to calculate the amount of sodium carbonate that needs to be added. My pool is around 17,000 gallons. At 10 drops I should add around 6 lbs of sodium carbonate but I'm at 20 drops. I tested my water at a pool store 4 days ago and my PH was at 7.0. I'm not sure how my PH could drop so quickly. Does this seem right?
How imperative is it that I get my PH to 7.2 before I start to SLAM?
Thanks!
FC = 2.6
CC = 2.4
CYA = 50
TA = 200
CH = 180
PH = Below 7.0
Thanks!
