pH level and fountains
chayne
0
the last week, it has been horrible here in North Texas. we have had heat indexes up to and over 110. my pool temp has been getting as hot as 93. i have turned on the sprayers trying to keep the pool temp down some. i know that this raises my pH. my question is, does pH go down on its own, or do i need to put some acid in to lower then raise my TA back up to normal?
Your test from a week ago shows a TA of 80 so you have a lot of room to add to acid.
Once pH reaches 8 or above, lower it to 7.6 with acid.
