Hi, I had a question that I can't seem to answer by just googling. My pool's pH keeps going low, requiring me to add alkaline (HTH Alkalinity Up). I notice this when the pool starts looking green despite adequate chlorine; when I then check the water with a test strip I'd see the pH reading below 7.2 and the alkalinity ppm low. Since it's a rather large pool I've taken to just adding 2kg of Alkalinity Up at a time; this would raise the pH and ppm to just above recommended (according to the test strips). However this summer (southern hemisphere) I've had to do this three or four times already, which is unusual, and now it has happened again. From doing some reading I see also that pH would be expected to go up over time, so I'm having a hard time explaining this. There isn't excessive amounts of leaves and debris getting in the pool, and while there has been higher than average rainfall, I can't imagine that it is enough to affect the alkalinity this much. I have been struggling with algae growth, but I can't tell whether this is a result of the alkalinity problem or the cause. It must surely not be normal to be adding 2kg of alkalinity on a monthly basis. Anyone got some insight and/or recommendations about this?
