pH is very high after adding baking soda
Horanis
13
Sylvania, OH
Hello all,
My chemistry prior to adding baking soda were:
pH: 7.1-7.2.
TA: 40.
CYA: 40
FC: 6.
Two weeks ago I added soda ash to increase pH to 7.4 and it worked but today pH came back to 7.1-7.2. I thought this was likely due to low TA. I decided to increase TA to 50-60. I used Pool Math and recommended to added 2 lbs, 3 oz but I added only 2 lbs baking soda and waited 6 hours. I just retested pH and it is above 8 and TA is 50. Water is clear.
I thought baking soda does not affect pH much. So what happened here? Should I add muriatic acid or wait a day and retest again?
P.S. Did not SLAM recently.
Thank you.
mknauss
51,238
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The data does not add up. I would test again tomorrow.
Are you using trichlor to chlorinate?
