I've read several posts some dating back awhile regarding high ph (8.0 and even higher) and some seem conflicting or not as concerned as others. So, i thought i would start a new post just to see what responses I get for my situation.
I believe my signature has the details but i have a fiberglass pool (installed summer 2015) with sand filter and in-line chlorinator (which i shut off and strictly use household bleach, which i understand naturally has a higher ph, for sanitation due to a problem i had last year with high CYA and maintaining FC levels - which is now resolved after draining/filling and SLAM).
my ph has been fluctuating around 7.8-8.2 with everything else WNL when comparing to the chart for fiberglass pools. should i be that concerned about lowering the ph to 7.6 when everything else is good? i have added some muriatic acid (based on pool math) three times now without much if any change in ph. sometimes, it seems to be even higher the next day after adding muriatic acid. i thought it might be my reagents (bought it end of last summer) so i purchased a ph meter, calibrated, and it came up with similar results - 8.1. we haven't had much if any rain which understand can cause ph to rise. i do keep my pool open over the winter months and only circulate when below freezing or as needed for cleaning/adding chemicals.
latest pool chemistry
Chlorine - 4
TA 100
CYA 40
Calcium hardness 230
some posts say don't worry if all else is well while others seem to be really concerned when ph is 8.0 or higher and the need to add chemicals to lower it. just want to see what the general consensus is present day.
thank you
Chlorine - 4
TA 100
CYA 40
thank you
