This is my first season with a fiberglass pool (or any pool for that matter), I do not have a SWG but use liquid bleach. My PH tends to stay on the high side, even after I lower it, it creeps up again. My numbers were FC 5, TC 5, PH 7.7, TA 100, CH 250, CYA 40ish. I lower my PH to 7.4-7.5, thus lowering my TA, it creeps back up to 7.7ish. Lower it again, creeps back up after about 2 days.
I was was hoping to find a TA that the PH liked and stayed steady. It does not seem to be on the lower end of the scale as my TA now is probably in the 60-70 range. I thought maybe a TA on the upper end, 110ish, would help but then read that high TA tends to increase PH.
Do I just need to accept a PH on the upper end and not worry about getting it to the middle? Is this just what my pool likes?
