Can adding clorox raise PH and Total Alkalinity? I have added dry acid twice to get both down and all I have added is some clorox. Had my Alkalinity at 120, lowered to 90, and a week later it is 130.
Check your fill water pH/TA/CH. It is the primary source of carbonate alkalinity.
Also, you really don't want to use dry acid in a swimming pool. It raises the sulfate levels which can cause long term damage to plaster and metal surfaces. It's best to stick with muriatic acid for pH control.
Re did my test and it was only 100, Not sure what happened, Now i have added dry acid I'm sure it will drop. Is there a more acurate ph test other than the color test in the taylor kit?
