pH and my Spa spillover
Pauly B
Active member
Apr 25, 2019
26
Houston
Hi all. Wish I could have found an underwater picture but by looking at this can this spillover cause enough aeration to raise my pH? Running pump around 9 hours a day now. Going from 7.4 to 7.7 to 7.8 every day and half. Pool was redone in April with StoneScapes mini pebbles.
While I'm at it, any advice on removing the scale using Muriatic Acid? Me thinks the pool care guy didn't do much water treatment last year before I took over.
Thanks
108514
Yes. And if there's an air inlet to create bubbles in the spa that will do it, too.
If you're talking about the white line at the water line or above, then mix up some 1:3 acid water in a spray bottle. I'd get in myself, and spritz it, let it foam a bit, scrub with brush (Doesn't have to be a pool brush, a nylon kitchen scrub brush will work) and then rinse by sloshing some pool water over it all.
Thanks. Four returns in spa but no bubbles there. So can anyone think of a way to have my spillover water not splash into pool? Racking my brain for ways to get the water to return smoothly back into pool.
Just stop running the spillover all day. Only need maybe two 15 minute periods to keep the chemistry balanced in the spa.
What is your TA? That can drive the pH up quicker if too high.
108553
I have a bypass to the spa upstream of the 3 way valve.
I just turned my pre pump 3 way to the middle position and it is now returning from the spa and the spill stopped. Level is dropping so I will turn it partially for spa return. Only have one combo skimmer (main drain and skimmer) and don’t want to reduce its efficiency.
Turned 3 way partially to add some return to the spa in addition to the bypass.
Potentially silly question but the 3 way valves don’t need to be full one way or the other. Right? Seems I should be able to balance spa drain and return to keep it full but not spillover?
Thanks
Pauly
For day-to-day I only return a small amount to the spa and draw nothing from it.
Trying to balance intake and return to the spa is flirting with disaster. If anything happens -- say the skimmer basket gets overwhelmed and clogged -- then you will draw more from the spa than you return. Which means eventually you may empty it and start sucking air. Run the pump dry too long and it will overheat and warp and leak.
You have a spa makeup line so the spa always gets a supply of filtered water added to it. Shut off everything else to-and-from the spa unless you're actually using the spa and want it heated and bubbling.
You are correct that those three-way valves can be set anywhere between stops to blend the flow.
In my skimmer I have a float valve and a line from the main drain. Would that alleviate risk of running spa dry if skimmer shut down?
Set it up as Richard is explaining.
Without automation you can not do what Jason suggested. You will always deal with rising pH due to the equipment you have.
How are you going to chlorinate while you are away? If with trichlor tablets, they are acidic and will take care of it for you.
Was going to bring chlorine up to 12 or so. Add at tonight after sunset and be home mid afternoon Sunday.
I can do tabs in a floater. With CYA at 50 how much would 3 days of tabs add to that?
