- Aug 7, 2022
- 17
- Vinyl
- Pentair iChlor 15
Is there the ability to put in the percentage you are running your SWG at. I see the magnifying glass but when I pick ichor 15 it just defaults to .6 lbs per 24hours. I assume this is at 100% so you need to do the manual calculation yourself? it would be cool if they let you put in your output percentage.Raise your FC to at least 6 ppm with liquid chlorine now.
What SWCG do you have? You can use Poolmath to see what FC it generates based on your % setting and pump run time.
