Pentair Whisper Flo VST
letme
1
New Mexico
We are having a VST pump installed indoor pump room. It is a replacement. The location is limited and already crowded and the control panel box really needs to be turned 180 degrees so it opens opposite how it does from the factory. Is it possible to turn the control box facing the opposite direction?
Do you have the exact pump model #...
Most of the whisperflow's drive kit plug into the motor on the rear, so orienting it the other way would reverse pins 1 & 3. The bolt holes are also a 2 and 1 pattern.
It may be possible that the drive cover can be rotated 180 degrees. The drive kit cannot. You will need the EXACT pump part number. Some can be changed, some cannot.
I would call pentair to confirm for YOUR model #
Pentair Drive Cover With Control Panel For SuperFlo and WhisperFlo VST Pumps | RS- 485 | 356279.
It looks like the drive cover is not perfectly symmetrical, so it probably cannot be rotated.
You could probably run 3 wires from the drive to the motor and mount the drive wherever you want if the pump is inside.
Reactions: PoolStored
If you mount the drive somewhere other than the motor, you will need to make sure that the wire connections are safe and secure including protection from water and debris.
This is not a recommendation to do this.
Do your own research before deciding what to do.
All decisions are at your own risk based on your own research and your own assessment of the suitability of the modification.
