Hello,
I've read over a lot of threads pertaining to VSF pump run-times and Id like to get input from everyone for my pool setup.
I run a Pentair VSF pump and my pool is 13.7k gallons.
I am looking at my screen logic intelliflo page and I have the speed set to 1250 RPM and its using 125 Watts. I get charged 11 cents per kWh so if I wanted to run my pump 24/7 it would cost around $10 a month to run.
As it stands right now I get lots of leaves and other Crud sitting on the water and it just doesn't seem like running the pool at this speed from 8am-4pm is cutting it. Should I try to fine tune my system to different speeds throughout the day?
Id like to keep my total monthly run-time cost at around $10 max.
Is running the pump 24/7 bad for the pump? will I be decreasing its life more so than just running it at higher RPM for shorter amounts?
Any insight would be appreciated
