Pentair VSF programming question
Chuckiechan
637
Roseville, CA
I used the “time out” function to do some maintenance. Then I pressed “program 1”. How do I get it back into the program so it shuts itself off. Its past shut off time, and it is still running.
Thanks in advance.
EDIT: I think I stumbled in to it.
Best to use SERVICE when wanting to control the pump. Then when you go back to Auto, your normal schedule will run.
I’ve only got “quick clean”, “time out”, “start/stop”, “reset” buttons. No service or auto.
I think I got it though. When they replaced my motor, they replaced the electronics too, and I think it did go directly from time-out to on-off (meaning on to run program).
I’ll be experimenting until I get used to it. BTW, I took your advice and run at 1000 RPM.
