After changing to the Pentair VS pump a couple years ago we’ve started noticing the breaker will trip for no reason. I’ve read that the VS pump works better on the Siemens GFCI breaker. While looking over things I noticed that the pump is wired to a separate box with the GFCI breaker (1) then goes into our main panel to two regular style breakers(2). If we have the GFCI (1) replaced with a Siemens breaker, will it still trip since the current will then go through the regular breaker in the panel box?
