Hi,
This unit is sucking air. When I run water over it (the shaft area under the handle) the air stops accumulating in the adjacent pump.
The housing does not appear to be leaking.
1. Replace O rings first?
2. Replace entire thing?
3. Can someone give me a link to better understand the function of this valve and the actuator? I know this was set originally to allow some shared flow between pool and spa - but I'd like to better understand how the pin settings affect flow left to right when I reassemble.
Thanks! Bob
Thanks! Bob
