I've had a Pentair UltraTemp for a little over a year. It works fine but when the filter pump is off the heat pump periodically turns on for a few seconds and then turns itself off. I started noticing this at the end of last season...not sure, but I don't think it did this when it was first installed. There are alarms: LOW WATER FLOW (obvious) and HIGH REFRIG (which I've read can be associated with low water flow as well).
I do not have any automation. The installers said it would not run when the pump is off. Do I need automation to have this work properly or is something else going on. Thanks in advance!
