- Oct 31, 2023
- 7
- Plaster
- Pentair Intellichlor IC-40
Hi I was wondering if anyone has advice on my Pentair Ultratemp 120Q.
First it heats without issue, but randomly on start-up (I would say once a week or so), the compressor make a loud racket on startup and keeps making a similar noise while running, the pitch and sound decreases over time, but then also increases. (Once I shut down the heat-pump and it starts back the compressor sound is normal). The fan works and sound normal throughout each start-up. I thought the rotor might be locking (might still be true, but the compressor doesn't shut down and I don't see the amps jump either).
I see via my energy monitor that the total amp draw of the fan and compressor is 34-35 amps (while making the noise and during normal startup/run). I didn't notice any spikes in the amp draw, but I also don't have an ampmeter for startup amp fidelity.
The last time this happened, I checked the capacitor, both fan and Herm (compressor) are within spec, I don't see any damaged or burnt wiring on the contactor or compressor or capacitor, or anywhere else for that matter, the voltage draw seems normal 236V on the incoming.
Any advice, before calling a tech?
Thanks!
PS I recorded the screech soon after startup for about 3 minutes (within 1-3 ft of the heater) and then shutdown the heater, with my iphone. Sound file is zip and attached below.
Thanks!
