- Jan 3, 2023
- 327
- Plaster
- Pentair Intellichlor IC-40
Does anyone happen to know if a regular FPT 2" union will work to replace the unions that come with the IC series SWGs and will it work (o'ring line up, etc...)? Looking at this one
I have one that has developed a leak at the joint (likely because of a crappy prime/cement job) and I don't have room to cut out the joint. I need to cut out the bad section and use a new side of the union. Only need one. I might try some pipe epoxy but I have never had good results with it and will have to replace it at some point anyway.
Or better question is does anyone know where I can get just one Pentair union?
