- Apr 19, 2022
- 21
- Plaster
- Hayward Aqua Rite (T-15)
Hi all, I'm afraid I broke my pump yesterday. I was attempting to wire it for external control with some relays. The external control didn't work for some reason, then I decided to just go back to local control, and the pump will no longer start. The keypad turns on, but when I try to start the pump it starts to spin, but then stops. Meanwhile the keypad is cycling from lit to blank. It goes through this several times, and will eventually show error 0017 on the display. I attempted a reset by holding 1 and the up and down arrows. No change.
I'm guessing I need to replace the drive kit, but I'm reaching out to see if there's something else I should try to bring it back to life first.
