- May 3, 2007
- 16,974
- Plaster
- Hayward Aqua Rite (T-15)
Did you re-vent the gauge? With an oil filled gauge, any significant temperature change can easily change the gauge reading by 1 psi.
Second, the installation manual says the suction pipe should have a 10 inch straight run before the pump inlet. These guys cut that down to maybe 6 inches. Is this a major issue or minor?.
My TFT guage varied from 9psi in the early morning to 5psi on a 100°F afternoon despite the fact I followed the venting instructions. Eventually I solved this by leaving the brass vent plug pulled out all day. A fair amount of oil seeped out over the course of the day and the guage had been consistent ever since.Ok, need to know if I have a problem. Cleaned filter as psi was up to 26, 7 on low speed. Immediately after cleaning psi dropped to 18.5 and 6.5, respectively. The next day psi had dropped to 17.5 and 5.5. Is this a problem or just a normal fluctuation?
The pressure gauge is only 3 months old and bought it from Trouble-free, the oil filled variety.
