- May 3, 2007
- 16,974
- Plaster
- Hayward Aqua Rite (T-15)
If the jets are 7/16", you will want at least 20 GPM per jet and 80 GPM total so the Superflo would be under powered for that application.
Your current pump is a 2 HP up rated pump with is the same as a 1.5 HP full rated pump in the same pump line. If you are interested in a Whisperflo, the WFDS-6 or WFDS-28 would be about the same size to your current pump. But because of the piping size, going a size up in the pump would probably not benefit you much.
