Pentair Superflo VS Error Code 000f
Gsandoval0135
1
Apple Valley, Ca
Hi, I just changed the breaker for my pool because there was almost no voltage going to my timer box to power my pantair superflo vs, there was no power but when enoughjuice would flo to the pump it read Error000f. I replaced the breaker and now I have enough voltage powering my pump and timer box but now my display board keeps saying Error000f... I factory reset and it still says the same error
Could it be possible the display box is fried now... does any one know what's is going on?. Thank you in advance
ajw22
18,072
Northern NJ
Welcome to TFP.
What voltage do you measure between L1 and L2 at the pump?
Turn off the breaker, wait 5 minutes, and power it back on. Try doing it a few times.
@JamesW
JamesW
19,364
Absolute AC Under Voltage Detected:
This indicates that the supply voltage has dropped below the operating range of 99v.
This could be caused by normal voltage variation and will clear itself.
Otherwise there could be excess voltage sag caused by improper installation or improper supply voltage.
Check the voltage between L1 and L2 with the pump off and then on.
