My Pentair Superflo had a short in the feed that damaged the main board in my Jandy salt cell. Rewired pump and replaced board and everything works fine except whenever the pump is running the salt cell is not getting 60 Mhz and will not generate.
If the supply to the cell is 25 Hz with the pump running, is it possible you have the cell wired to the pump motor after the variable frequency drive? As an experiment, increase motor speed until you read 60Hz or so at the cell. Does it work properly when you do that?The Hz is 25 with the pump running, 60 when it is not. The voltage is 118.
