Hello Group.
I have the above pump and it has developed a leak where the metal band joins the 2 cases together. The parts that I need, I cannot find. I have searched high and low. I have already replaced the seals and orings. I just need the 2 cases. The seal plate and the tank body assembly. Anyone got?
Pentair customer support has not been able to suggest anything. To the point, they are worthless to even waste a call to.
I thought about replacing the entire pump, but #013004 cannot be found in stock. What alternative Pentair pump can be used that is compatable with my control center? Something someone might have in stock......maybe.
Thank you.
Steve
Thank you.
Steve
