Pentair Screenlogic app on Android....too many AUX and Features buttons
Veccster
0
359
Pittsburgh PA
Anyone else using the Pentair Screenlogic app on Android? I have 3 features that I select from - Slide, Waterfall and Deck Jets. But I have 12 extra buttons in a random order on the app. I know it's a minor issue but the app should give you the option to hide unused aux and feature buttons.
/rant
HI, do you have the software loaded on your computer too? If so, go into the screenlogic program. When you are at the screen asking for system info, bottom right is a tab for "Configure Screen Logic". A new screen will load and you will have to click another button configure screen logic. A new screen will open. Follow the bottom prompts to the next page, setup circuits (step 2 of 5). You will see all your circuits active and not. Click on each circuit and in lower right you will see a drop menu to select where you want each to display. Select "Do not show". In about a minute they will disappear from the app.
I think it is easier on computer. But if you don't have it loaded, you can download the configure screen logic app and you can do the same thing on this app. It is different then the regular screen logic app. Hope that helps.
V,
Here is a pic of the config page you want to update.. Notice in the bottom right where you can select what you want to show up and where...
dbtgallery.php
And I agree with "golfing" that using the PC is much, much easier when programming...
