I have a Pentair chlorinator, but since learning about CYA here, I don't use it, but rather use liquid chlorine. However, when I did use it, I found the same thing as you. My return out of the filter splits with one side going to the pool and the other going to the spa. The chlorinator is on the pool side, not the spa. Since I run the pump at a low speed, and not all of the returning water goes past the chlorinator, there just isn't enough to feed through it. Again, since I don't use it, it doesn't really matter to me. If you have a good test kit, check your CYA, as using only the tabs, you may have too much. If my CYA gets low, I will use tabs for a couple days to bring it back up, but even then, I put the tabs in one of those floating things. My Pentair chlorinator just sits. Yes, I have tested it, and if I bring up the pump speed, it does get water pumped into it. I'm pretty new to pools, but from what I've learned here, I am at a loss to understand why there isn't available chlorine tabs with no cyanuric acid. Oh well.
