If you open the pump lid, the air is getting in before the filter, which causes the filter to drain out the returns. That’s OK. The main issue would be if air got in the filter at the filter or past the filter. If that happens, the water (and some DE) in the filter would drain back through the pump.
I would always add a check valve between the pump and filter.
