Just had pool redone with automation and when I turn on pump at night before a freeze it seems to turn off after 12 hrs. Sounds like using the Screenlogic app is the same as hitting the button on the Easy Touch that turns on pump for 12 hrs. (not sure which button). So to keep pump running longer I need to set schedule? I’d rather set schedule than use the freeze mode, since it alternates between pool and spa modes too frequently since I have system set to “pump off when valves operate”. Any other options?
