I have been through a lot of years on this pentair we-2 pump. Normally prime and run is no issue. I came home and no water was moving. Opened the volute and the water was boiling, apparently because the water was not cooling the motor.
This one has me puzzled. The motor runs fine, I took out the motor and impeller and it was clear of debris. I ran it as separated from the volute, runs fine. The impeller and motor turns without friction. I got a seal kit for it, and replaced the volute o-ring even though it looked fine. The seal between the volute and the motor housing also looks fine. It just does not prime, and it used to prime like a train a day or so ago, I have never had an issue with it. This pump has been operating fine for 5 years.
I tried some obvious stuff. There are two intakes, tried both of them so the input is not blocked. My next guess is that the front pump seal failed, and I am replacing that. I pulled and put the pump on a bench to replace that according to online instructions.
My question is, could the pump shaft seal be the issue? It seems to be taking in air from somewhere, but I went all around the system and couldn't find any obvious suction side leaks.
Thanks in advance.
Thanks in advance.
