LsiGuy
In The Industry
Aug 19, 2023
2
Bountiful, UT
Having an issue with pentair system. Able to log in remotely and see things, unable to have an effect on the actual system. from the panel i'm able to change modes and have the valves turn, but no changes with the pumps. the pump settings in the panel appear to be correct when it comes to correctly identifying the pumps. neither pump has communication to the panel. both stopped communicating after or shortly after replacing the salt circuit board, which did restore power to the swcg. I didn't do the work myself, but i am here to try to diagnose it. If you have any ideas or suggestions start throwing them my way. the one thing i haven't considered because i don't know how is to reset the eeorp or
however it's spelt in the panel.
Easy touch 8 panel.
Rob,
Most likely they screwed up the com wiring to the new Surge card..
If your Surge card is inside the EasyTouch, drop down the front panel and show me a couple of pics of your new Surge card, as well as the back of your main circuit card.
