Hello,
I recently installed a MasterTemp 300 and about to hook it up to my EasyTouch, however i am confused as to exactly where the "fireman's Switch" is that i need to disconnect. As a note, i will be hooking up a screen logic to the easy touch as well.
In another post, i received this response:
"Then open up the heater circuit board and remove the red jumper wire (that's connected to the "fireman's switch"). Then you need a 2 conductor wire that goes from the heater circuit board fireman's switch to the EasyTouch. It goes into the EasyTouch panel through the low voltage raceway, and up to the back of the EasyTouch circuit board to the HTR connection.
Then the heater has power whenever the pump is on. When the panel calls for heat, it sends a 24v signal from the EasyTouch Panel to the fireman's switch to tell the heater to turn on."
I have a 2 conductor 18 gauge wire ready to go the the EasyTouch which is fairly straight forward, but when i open up the MasterTemp, there are many "red" wires. Which wire exactly and i looking for and where would it be located. Do you just remove the red jumper wire, or do you plug it in somewhere else? Also, on the back side of the mastertemp when you remove the panel, there is an on/off switch. What is that for? It is just above where the gas line is wired in.
See pictures below.
See pictures below.
