OK, it's into weirdness now.....
Pentair MASTERTEMP heater: When initially engaged in SPA mode, works well and heats continually until it reaches 80-90 degrees. At this point, the "heat" light begins flashing, blower stays ON, but burner cycles OFF. NO red lights on panel OR on circuit board are ON. In about 30 seconds, burner cycles ON again, amber "heat" light is steady, and the cycle repeats. Here are the other things that were checked:
1. Thermistor tests perfectly and registers correct water temperature.
2. MAX temp set at 125 degrees.
3. HLS-AGS-AFS-WFS remain in normally CLOSED position during all cycling events. (therefore NO red lights on board)
4. Thermostat function tests normal and opens at 120 degrees.
5. Water flow/pump speed/internal bypass all normal.
6. Flue gas temperature does not get above 300 degrees and indicates normally.
At this point, I wonder about flame rectification issues, possibly ignition control module or even control board, although the indications lead me to believe the board is ok.
Any thoughts about this mystery are gratefully appreciated!
