Pentair mastertemp 400
eskandari_n1
In The Industry
Dec 28, 2024
32
Dallas, TX
Pentair mastertemp 400 is coming on as soon pool pump start. how to find out if is control board or other devices faulty. i stop it running by switch off heater on heater display. i lost whole tank of propane. I though we used it all after we refile the tank, realize heater come up as soon as pool turn, this when i turn of heater. thanks for any help
Welcome to TFP.
Is the heater connected to an automation controller?
Tradegrade Pentair 520545 Easytouch 8 Function Panel - Pool & Spa Combo W/ Ic40 Salt Cell
Read Pentair Automation Systems - Further Reading
A 2-wire cable connects the gas heater Fireman's switch to the heater relay on the PCB. The heater relay contacts can be welded shut from overcurrent and not open to turn the heater off.
You can check the relay using a multimeter with the wires disconnected and the heater off. The relay is bad if you have continuity with the heat off.
Also, check the relay driver as described in the linked Wiki.
what color are these 2 wire, how can i identify them? thanks
Show us this in your heater…
Did you disconnect the wires from the yellow wire nuts?
