Pentair mastertemp 400 shutting down after hitting 289
As soon as you see "Service Heater" you need to check the Fenwal and the back of the control board for error LEDs.
Check the flame current and the gas pressure.
The Fenwal has two test points for flame current FC+ and FC-.
The best way to measure the flame sense current is with a true RMS meter.
Measure the current with a good true rms meter that can measure dc current in the microamp range.
To measure flame current, connect a True RMS or analog DC micro-ammeter to the FC+ and FC- terminals.
Readings should be 1.0 µA DC or higher.
If the meter reads negative or below "0" on scale, meter leads are reversed. Reconnect leads with proper polarity.
If you don't have a RMS meter you can just test for voltage between FC+ and FC- terminals to confirm if you have flame sense.
Each micro-amp of flame current produces 1.0 VDC.
For example, 2.6 VDC equates to 2.6 µA.
Voltage is an indirect indication but easier to do with typical DIY equipment.
But it's still very difficult to measure unless you make up some pin wires to clip your voltmeter to.
Or you can order some insulated micro clips for the test.
The reading should be 3-8 volts and this corresponds to the millionth's of an amp signal your flame sense signal should reading.
If you try to check this be very careful since you can easily short the 24 vac circuit which can blow the transformer before the 2 amp fuse blows.
When not operating, the flame current should read 0 volts dc and 0 microamps dc.
DC amps and voltage should be zero when there is no flame.[6]
FC read 0 at DC with no flame
7.6 volts AC for FC with heater off.
You need to test for DC microamps or DC volts while the heater is firing.
The values should be 0 when the heater is off.
The "E01" code indicates an open water temperature sensor, called the thermistor on the parts diagram.
Thermistor p/n 42001-0053S Part 7 on page 54 of the MasterTemp Installation manual
