Old thread I know, but I removed my SFS and the "bolt" inside the flue came loose so is that normal? Just reuse it? Or is that bold/threaded piece supposed to be welded to the flue interanlly?
Should be a permanent part.Old thread I know, but I removed my SFS and the "bolt" inside the flue came loose so is that normal? Just reuse it? Or is that bold/threaded piece supposed to be welded to the flue interanlly?
Condensation getting inside can do that kinda damage. It’s kinda just how it goes.So I've been chasing a no ignition issue on my Mastertemp 400. Replaced the flue sensor, turns out that didn't fix it. Tested the ignitor impedence yesterday and it was at 5K ohms. So I am going to replace that. But the main issue I'm concerned with is all the rust in general. Quite alarming amount of rust all around the igniter mount. And there is rust all over in general. We are in Georgia if that matters. And I'll have to check and see if a sprinkler head is watering the unit inadvertently. So I guess I'll replace the heater lid. But why did it rust so bad? Maybe after 9 years this is acceptable?
This is most likely a condensation issue or related to the balance of your pool water.So I've been chasing a no ignition issue on my Mastertemp 400. Replaced the flue sensor, turns out that didn't fix it. Tested the ignitor impedence yesterday and it was at 5K ohms. So I am going to replace that. But the main issue I'm concerned with is all the rust in general. Quite alarming amount of rust all around the igniter mount. And there is rust all over in general. We are in Georgia if that matters. And I'll have to check and see if a sprinkler head is watering the unit inadvertently. So I guess I'll replace the heater lid. But why did it rust so bad? Maybe after 9 years this is acceptable?
Just to clarify, are you talking about the female nut internally welded to the flue?I thought so, I'll be reusing it thx for the feedback
Yeah I am contemplating a new heater. BUT, just for the sake of thought, why not replace the combustion chamber and lid instead of the entire heater? I'm pretty tool friendly and it doesn't appear to be that difficult. At Sunplay I see the chamber for 449.95 and the lid for 389.95. The whole heater is 3734.00.
Yes, I agree, especially with the "cascading" of problems. I've seen that too many time and would be very much inclined to tell a customer, "Sorry, new heater time."And when you take the lid off and realize that the heat exchanger is completely fouled up ... probably another $1,000 ... then you put that all back together and the blower goes .... another $600 .... then you replace that and gas valve dies ... another $500'ish ....
This is the problem with pool heater repair - the failures cascade and the repair bill gets bigger and bigger. Eventually you've dumped half the cost of new heater into an old one and that probably bought you another year of heater life ... before something else decides to fail. Major heater repairs are almost always a losing bet outside of warranty.
But lets get an expert opinion from someone who has probably worked on hundreds of heaters throughout his career ...
@1poolman1 ... what do you think?
Makes it lighter and easier to dispose of in pieces.Disassemble everything and show us what's going on inside the heater.
